Streaming is a big thing now, and audio equipment is no doubt an important part of it. For those who don’t want to deal with a standalone microphone, headsets are the undisputed solution to the issue. But for those who take their streams outdoors and would want something more discreet compared to the usual headsets, Razer may have the answer, in the form of the Ifrit.
The word discreet is key here, because the Razer Ifrit is not just a lot smaller than other headsets. Instead of the usual closed-ear cans, it comes with canal buds. And the band sits behind the head instead of on top. The only sticking point that would attract a lot of attention would be the microphone sticking out on the left side.
Another selling point that Razer is promoting through this hilarious video is that the Ifrit will not give you headset hair, or the mess that results from the headset band being on top of your head over long periods of time.
That said, it’s still a headset meant for gaming. And with that, it is also compatible with PS4 and Xbox One. It also comes with the USB Audio Enhancer which also acts as a USB to analog converter. You can also use the Audio Enhancer to use two Ifrits on one PC.
The Razer Ifrit is already on the Online Razer Store for the Asia Pacific region. It is priced at RM569.
