Biostar has unveiled its latest product in the form of an entry-level motherboard called H310MHC. The company has mentioned that its latest mainboard is aimed towards office and general home usage such as web browsing, office applications, light photo and video editing, as well as non-intensive gaming.
Biostar’s H310MHC is equipped with the H310 chipset, which is compatible with Intel’s 8th Generation Core processors. In addition, this chipset also supports DDR4 RAMs with frequencies up to 2666MHz (32GB capacity). Besides that, this motherboard is also fitted with one PCIe 3.0 x16 slot and two PCIe 2.0 x1 slots.
Protective components that come with the Biostar H310MHC motherboard are ESD protection, USB Polyswitch, and several others that protect against overvoltage, overload, and over temperature. Those aside, when it comes to design, the H310MHC mainboard features an all black PCB along with yellow-coloured components.
Unfortunately, the local pricing and date of release for the H310MHC motherboard was not mentioned by Biostar. Regardless, if you’re looking to create a basic PC for your home or office usage, which runs non-intensive workloads, then you should consider the Biostar H310MHC. Hopefully, the local pricing is adequate.
(Source: Biostar)
