It appears that HMD Global has more than just the Nokia 3.1 and 5.1 to announce. Hardware specifications of the Nokia 5.1 Plus has appeared on the TENAA database, complete with rendered images of what the phone could possibly look like at launch.
The listings shows that the Nokia 5.1 Plus will come with an as-of-yet unknown octa-core SoC that is clocked at 2GHz. Because the phone is expected to be aimed at the mid-range market segment, reports are forecasting that the processor could be one of two possible options: a Qualcomm Snapdragon 625 or MediaTek Helio P18.
Other specifications that were listed down include a 5.86-inch HD (720 x 1520) TFT display; 3GB, 4GB, or 6GB RAM; either a 32GB or 64GB internal storage configuration; a 3000mAh battery; and a USB Type-C port to faciliate charging and file transfers.
The page also lists down a 13MP dual-shooter for its rear camera, while its front-facing camera will reportedly only be getting an 8MP shooter. It’s also very likely that the Nokia 5.1 Plus will be an Android One device, just like the Nokia 3.1 and 5.1.
While there is still no release date for the Nokia 5.1 Plus, HMD Global is expected to release the Nokia 5.1 sometime in July. So there’s a possibility that the company might just release both the phones at the same and brand it as the Nokia 5.1 family.
(Source: XDA Developers)
