The Sony WH-1000XM2 over-ear headphones, which was launched at during IFA 2017, is widely recognised as one of the best wireless headphones with active noise cancelling (ANC) in the market. For a limited time only, you can get them for up to 27% off.
The headphones are the successor of the original WH-1000X, and comes with Active Noise Cancelling (ANC) and Ambient Sound mode. The WH-1000X also has an airplane-friendly Atmospheric Pressure Optimizing mode for more comfortable long-term use in the air, and a simple touch-based control on its earcups. The WH-1000XM2 also supports Sony’s Hi-Res Audio format, which offers high quality audio playback for supported formats.
Not only that, Sony’s WH-1000XM2 also features a whopping 30-hour battery life, as well as a quick charge function that gives 70 minutes of play time with just 10 minutes of charging. The headphones also comes with its own carry-case and cable, allowing you to plug the headset directly into an airplane’s in-flight entertainment system.
The RM1599 retail price is admittedly high for a pair of headphones, but for a limited time, you can get them for just RM1163 – about 27% off its retail price. A seller on Lazada is offering the Black colourway for RM1203, while Lazada itself has some promo codes that shaves up to RM40 off the price tag – but they are limited, so it’s best to cop them when you can.
