AMD has revealed key specifications of its upcoming lineup of desktop-grade Raven Ridge APUs. For those who may be out of the loop, Raven Ridge APUs are based off of the company’s Zen CPU architecture. In addition, these processors employ the AM4 socket as well. To be more specific, AMD’s upcoming processors are called Ryzen 5 2400 and Ryzen 3 2200G.
What makes both the Ryzen 5 2400G and Ryzen 3 2200G even more “enticing” is the fact that they feature an integrated graphics solution based on Radeon’s Vega GPU microachitecture. Those aside, let’s first take a look at the specifications of the AMD Ryzen 5 2400G. This APU is apparently going to come with four CPU cores and eight threads.
The Ryzen 5 2400G is capable of a base frequency of 3.6GHz and a boost clock of 3.9GHz. Besides that, this APU has a TDP rating of 65W as well. In the graphics department, the Ryzen 5 2400G is equipped with the Radeon Vega 11 integrated graphics solution, which features 11 graphics compute units and a GPU frequency of 1250MHz.
Next up is the slightly less powerful, Ryzen 3 2200G APU. This processor comes with four CPU cores and four threads, which is capable of frequency speeds of 3.5GHz (base) and 3.7GHz (boost). The TDP of this processor is rated at 65W, similar to the Ryzen 5 2400G. Graphics-wise, the Ryzen 3 2200G is fitted with Radeon’s Vega 8 integrated graphics. This iGPU comes with eight graphics compute units and is capable of frequency speeds of up to 1100MHz.
It’s also worth noting that both the Ryzen 5 2400G and Ryzen 3 2200G will be bundled with AMD’s Wraith Stealth CPU coolers as well. Regardless, both of the aforementioned processors are expected to officially be launched on 12 February this year; so expect more details like pricing and date of availability to be announced by then.
