Over the past few weeks, Cooler Master has launched plenty of new products for PC enthusiasts and gamers in Malaysia. One of them is the MasterBox MB600L mid-tower case which comes complete with edge-to-edge transparent acrylic side panel with full black internal coatings and PSU cover.
This case also has enough clearance to support up to 360mm water cooling radiator, 400mm graphics card, 160mm CPU tower cooler, and 180mm PSUs. Not enough with that, it is also able to be fitted with up to four 120mm fans in total.
Available with Red, Blue, and Gunmental side trims, the MB600L case can be used with either ATX, Micro-ATX, or Mini-ITX motherboards. For those who have a bigger budget, they can opt for MasterBox Pro 5 instead.
As opposed to acrylic side panel, the MasterBox Pro 5 features a 4mm thick edge-to-edge tempered glass side panel as well as a transparent front panel. It also has enough space to support those gigantic E-ATX motherboards and 410mm graphics cards.
Not to forget, Cooler Master has also brought over MasterBox Pro 5 RGB into Malaysia which features three pre-installed 120mm RGB fans on its front together with another standard 120mm fan on the back. It also comes with 1-to-3 splitter cable that is compatible with ASUS AURA Sync, ASRock RGB LED, GIGABYTE RGB Fusion, and MSI Mystic Light Sync RGB systems on motherboards made by respective manufacturers.
Readily available in Malaysia through Cooler Master Malaysia’s Lazada and Shopee stores as well as its dealers nationwide., the new MasterBox MB600L goes for RM 199 while the MasterBox Pro 5 can be obtained for RM 339. As for the MasterBox Pro 5 RGB model, it is priced at RM 399.
