The Huawei Mate 10 and Mate 10 Pro are Huawei’s latest flagship smartphones, and they are arguably the Chinese company’s most exciting devices yet. If you’re planning to get either one of these two phones – or you’ve already pre-ordered the Mate 10 – here’s a look at what you get in the box.
Out of the two phones in the series, the Mate 10 Pro is the more exciting one. In comparison to the standard Mate 10, it is water- and dust-resistant, and it also has a sleeker-looking 6-inch 18:9 OLED FullView Display. The Mate 10, on the other hand, sports a more conventional 5.9-inch 16:9 FullView Display.
Both devices are equipped with the same Leica-certified dual-camera system with large f/1.6 lenses, and if you’d like to see how it performs, you can check out our blind camera comparison right here.
