Samsung Patents Its Own Multi-Device Wireless Charger, Might Rival Apple AirPower
by Sharil
October 25, 2017
SamsungPatent
Revealed alongside iPhone 8 and iPhone X, Apple AirPower allows users to wirelessly charge multiple devices at one time. As it turns out, Samsung is working on such charger as well since earlier this year.
According to patent documents that have made their way online, the charger which uses both magnetic resonance and magnetic induction charging method is able to support two device simultaneously. The charger is apparently able to intelligently determine the correct magnetic charging method for each device.
SamsungPatent2
The combination of devices that can be used on the wireless charger.
The charging standard that will be used on this charging pad is not known at the moment but given that the Qi standard is able to support both magnetic induction and magnetic resonance, it is possible that Samsung’s charger will be adopting that very standard.
As you can see from the images above, the charger is able to support smartwatch as well. It is not known whether the patent above will eventually be turned into an actual product but it is certainly something that would be useful for users that own multiple Samsung Mobile products.
(Source: Patently Mobile )
Related Article Samsung’s First Clip-On Earbuds Pictured In New Leak; May Launch As Galaxy Buds On
Filed Under Samsungsamsung mobileSamsung PatentsSamsung Wireless ChargerWireless Charger
Updated 2:42 pm, Wed, 25 October 17
    Wearables
    Casio G-Shock 2500 Series Launches In Malaysia
    PC
    Gaming
    Metronomik Showcases “Wayang Kulit” Inspired Villain In No Straight Roads
    Tablets
