Ever thought to yourself “man, I wish my PC would look less dull and boring.” Well, Cooler Master has got just the right components to make your PC shine bright like a diamond. The company has announced the availability of its MasterFan Pro RGVB Series, RGB LED Controller, and RGB Splitter Cable in Malaysia.
Cooler Master’s MasterFan Pro Air Balance RGB was first debuted at CES 2017, which apparently is a first for the company. Since then, Cooler Master has unveiled two more iterations of the MasterFan Pro 120 cooling fan: Air Flow RGB and Air Pressure RGB. In addition, the company also showcased 140mm versions of the aforementioned cooling fans as well.
Next up is the Cooler Master RGB LED Controller. As most of our dear readers may know, not all motherboards in the market today are equipped with RGB headers. Thankfully, this “problem” can be solved using the RGB LED Controller, which allow consumers to add LED strips onto their system as well as to control other LED-lit components. According to Cooler Master, its RGB LED Controller is compatible with Asus Aura Sync, ASRock RGB LED, MSI Mystic Light, and Gigabyte RGB Fusion.
Lastly, Cooler Master also has the RGB Splitter Cable. The company mentioned that this product “allows users to extend multiple RGB LED fans and strips to build up aesthetically beautiful systems.” Like the RGB LED Controller, Cooler Master’s RGB Splitter Cable is also compatible with most motherboards from major manufacturers.
When it comes to pricing, the MasterFan Pro 120 Air Balance RGB, Air Flow RGB, and Air Pressure RGB comes with a modest price tag of RM99 each. Meanwhile, the larger MasterFan Pro 140 Air Flow RGB and Air Pressure RGB is priced slightly higher at RM109 each. That aside, the RGB LED Controller and RGB Splitter Cable are priced at RM149 and RM29 respectively.
Cooler Master is also offering a 3-in-1 pack, which includes the MasterFan Pro 12 Air Balance RGB and RGB LED Controller – priced at RM299. All of the aforementioned new products by Cooler Master is now available through selected local retailers.
