Linus Tech Tips is back yet again with another PC build guide and this time it’s all about RGB. If you’re anything like me, you can’t get enough of shiny lights illuminating the innards of your PC.
Linus went with the InWin 805 Infinity for the PC casing, an Intel Core i5-7600K for the CPU, and a 64GB G.Skill TridentZ kit for the RAM. For the motherboard to hold it all, he opted for the Asus ROG Maximus IX Hero. Topping it all off are two Asus Strix Nvidia GeForce GTX 1070 in SLI configuration.
For the finishing touches, he has a total of six Corsair RGB fans and four LED strips. All of them compatible with Asus’ Aura Sync lighting system. He even replaced the power supply’s stock cooling fan with a Corsair RGB unit.
Check out the video for yourself to see the PC build in all its flashy epicness.
