  • Wanista
Home Mobile
OPPO R11 Finally Goes Official, Alongside R11 Plus
OPPO R11
This particular device is pretty much an open secret but nevertheless, OPPO R11 has finally received its official launch in Shenzhen today. Alongside the new phone is R11 Plus which is essentially its bigger twin.
In addition to the similarities between their physical design, both devices share plenty of components with each other. For example, both R11 and R11 Plus are actually powered by Qualcomm Snapdragon 660 processor and carries 64GB internal storage.
OPPO R11
Both R11 and R11 Plus are also depending on the combination of 20-megapixels and 16-megapixels sensors as well 2x optical zoom for their rear camera. At the same time, there is also a 20-megapixels camera on their front side.
So, what made them different from each other? Well, their sizes is one of the most obvious way to separate them apart as R11 is equipped with 5.5-inch display while R11 Plus carries a 6-inch display. However, both smartphone have the same full HD resolution.
OPPO R11
Both devices also feature different amount of RAM with 4GB for R11 while R11 Plus carries 6GB. Not to forget, they also have different battery capacity since R11 has 3,000 mAh which is lower than R11 Plus’s 4,000 mAh.
Logically, they should be some differences in terms of pricing as well. However, OPPO decided not to reveal the price tags of either smartphones and stated that they will be revealed on its online store in China tomorrow instead.
(Source: OPPO – 1, 2, 3 // IGAO7)
Filed Under OppoOPPO ChinaOppo Dual Cameraoppo r11
Updated 10:15 pm, Fri, 9 June 17
http://lowy.at/bING6
Share1Tweet1SendShare
    Banking
    E-commerce
    Android Phones
  • Wanista
