A spin-off brand from ZTE, Nubia has apparently released two new smartphones into Malaysia that are called M2 and M2 Lite. While there might be no official announcement from the brand just yet, both smartphones can now be obtained through Lazada.
Powered by Qualcomm Snapdragon 625, one of Nubia M2’s main is its rear camera which contains two Sony sensors with one being a 13-megapixels RGB sensor while the other one is a monochrome sensor with the same resolution. The camera also comes with sapphire-based F2.2 lens and dual-tone flash.
Featuring metal frame, the M2 also carries another 16-megapixels and F2.0 wide-angle lens on its front. The phone also comes together with 5.5-inch full HD AMOLED display, 4GB of RAM, 64GB internal storage, and 3,630mAh battery.
As for Nubia M2 Lite, it is powered by MediaTek MT6750 octa-core processor alongside 4GB of RAM and 32GB storage. Also features a metal unibody chassis, Nubia has also equipped with the smartphone with 5.5-inch HD display, 13-megapixels rear camera, 16-megapixels front camera, and 3000mAh battery.
According to the listing on Lazada, the M2 is priced at RM 1,899 while the M2 Lite can be purchased at RM 1,199. More information about both smartphones can be obtained through Nubia’s official website for Malaysia.
(Source: Lazada Malaysia via mdroid. Thanks for the tips, KevinNgTK!)
