MSI has unveiled its lineup of super cute RX 560 graphics cards. These are the RX 560 Aero ITX 2GB and RX 560 Aero ITX 4GB. As their name indicates, the only major difference between both custom RX 560 graphics cards are their respective VRAM capacities.
When it comes to design, both the RX 560 Aero ITX 2GB and 4GB graphics cards come with a minimalistic all black cooler shroud. In addition, these graphics cards are also only fitted with a single 90mm open-air cooling fan. Dimension-wise, both graphics cards has a PCB length of merely 15.5cm, which is perfect for compact systems.
It’s worth noting, however, that MSI’s newest custom graphics cards do come with a two-slot thick cooling solution. That aside, both custom RX 560 by MSI boasts base and boost clock speeds of 1196MHz and 1320MHz respectively. Memory clock speed is rated at 7000MHz. Besides that, the RX 560 Aero ITX graphics cards are also equipped with one DisplayPort 1.4, HDMI 2.0 and DVI display output ports each.
Unfortunately, MSI has not mentioned the local pricing and date of availability for both of its custom RX 560 graphics cards. That said, these graphics cards are currently being sold in Europe for around €100 (about RM482) for the 2GB variant and €130 (approximately RM626) for the 4GB model.
(Source: TechPowerUp, Guru3D)
(Featured image: TechPowerUp)
