Said to be able to deliver comfort and performance in one single package, Corsair recently has unveiled its brand-new Glaive RGB Gaming Mouse. Interestingly, the freshly announced mouse is now already available in Malaysia.
One of the Glaive’s main attraction is its interchangeable thumb grip which allows gamers to tune the mouse’s comfort level to fit their personal preferences. Included alongside the mouse are three grip options: smooth curves, rubberized grip, and wide thumb rest.
The Glaive also features a custom PMW3367 16,000 dpi optical sensor that was developed in partnership with PixArt and its sensitivity can be set to as low as 100dpi in 1dpi steps. Not to forget, the mouse also features Omron click switches that apparently durable enough to last up to 50 million clicks.
Alongside polling rate of 1ms, there are three RGB LED zones throughout the mouse that can be customized using Corsair Utility Engine software which also supports macro recording and button remaps. Since the mouse is also equipped with 8MB onboard memory, gamers are able to carry their settings everywhere.
As mentioned earlier, the new Corsair Glaive RGB Gaming Mouse has already made its way into Malaysia and should appear at your favorite retailer immediately for RM 349.
(Source: Corsair)
