Colorful has announced the specifications of its upcoming graphics card called the iGame GTX 1080 Ti Vulcan X OC. For those that may remember, we wrote an article about this graphics card a few weeks ago; you know, the one that’s supposedly equipped with an LCD display.
As previously detailed, the iGame GTX 1080 Ti Vulcan X OC comes with a triple-fan cooling solution. In addition, the graphics card is also fitted with a flamboyant cooler shroud, which is aptly coloured in black, red, and silver. Also not forgetting the LED display found on top of the graphics card, which apparently is able to display information regarding the graphics card’s clock speeds, temperature and fan speed.
When it comes to performance, the iGame GTX 1080 Ti Vulcan X OC comes with base and boost clock speeds of 1620MHz and 1733MHz respectively. Memory clock speed is rated at the standard 11008MHz. Meanwhile, the graphics card also features a 16+2 phase power design, which makes it adequate for aggressive overclocking – if you’re into that.
Unfortunately, aside for its specifications, the pricing and date of availability of Colorful’s iGame GTX 1080 Ti Vulcan X OC was not announced. As mentioned in our previous article, it seems very unlikely that this graphics card will be made available in markets outside of China – but let’s hope it does anyway.
(Source: VideoCardz)
