Well, that was quick. After just about a week since Digi launched its online exclusive Digi Postpaid Infinite plans, the telco has already ended the offer for the cheaper option – Digi Postpaid 80 Infinite.
According to Digi’s website, the Digi Postpaid 80 Infinite is no longer available for sign up. The plan previously offered infinite calls and infinite internet limited to 5Mbps. You need to pay for tethering, but for the first 10,000 subscribers to the plan, the telco will throw in free tethering (5GB each month worth RM10) for 12 months.
Digi did not provide a reason behind removing the Postpaid 80 Infinite. Meanwhile, the Digi Postpaid 150 Infinite plan is still available, so if you wish to get it, you may purchase it with a new number, port in using your existing number, or switch plan for existing Digi subscribers.
If you wish to sign up for Digi Postpaid 150 Infinite, you may do so on the telco’s website now. The offer is supposed to end on 24 June 2017, so let’s keep our fingers crossed that Digi will not quietly end this promotion as well.
