Gigabyte has released the specifications for one of its custom GTX 1080 Ti graphics card. The card in question is the Aorus GTX 1080 Ti 11G, which looks almost identical to the company’s GTX 1080 Ti Aorus Xtreme Edition graphics card.
As expected, the cooler shroud of Gigabyte’s Aorus GTX 1080 Ti 11G features an all black design. In addition, the shroud also comes with the company’s signature Windforce cooling solution, which comprises of three 100mm cooling fans. Besides that, the graphics card is also kept cool with the help of a backplate too.
When it comes to performance, the Gigabyte Aorus GTX 1080 Ti 11G features two clock speed presets: OC mode and Gaming mode. In the latter mode, clock speeds are rated at 1569MHz (base) and 1683MHz (boost). Meanwhile, OC modes pushes the base and boost clock speeds of the graphics card to 1594MHz and 1708MHz respectively.
Connectivity options of the Aorus GTX 1080 Ti 11G include one DVI port; three HDMI 2.0b ports; and three DisplayPort 1.4 ports. As with other recently revealed custom GTX 1080 Ti graphics cards, the Aorus GTX 1080 Ti 11G draws power via two 8-pin power connectors. Unfortunately, Gigabyte made no mention of the price and release date of this graphics card.
(Source: Gigabyte)
