Ever wanted a graphics card that comes with something ‘a bit extra’? Well, look no further, Colorful has got the right card for you. The Chinese company has unveiled its latest graphics card called the iGame GTX 1080 Ti, and it comes with one interesting feature that’s rarely found on modern cards.
Colorful has decided to equip its iGame GTX 1080 Ti graphics card with a built-in LCD display. Interestingly, the LCD display on the graphics card reads out the temperature, clock speeds, and fan speeds of the card. Normally, one would have to rely on software to be able to determine those readings.
In addition, Colorful’s iGame GTX 1080 Ti is also fitted with a really neat looking cooler shroud called “Shark Bionics.” The shroud features two 92mm fans along with a PCB that’s said to feature a 16+2 phase power design. It’s also worth noting that the cooler shroud on this graphics card is estimated to be at least three-slot thick.
Of course, as with other recent graphics cards, the iGame GTX 1080 Ti comes with RGB LED elements as well. Besides that, the graphics card will also draw power from two 8-pin power connectors. The estimated release date for Colorful’s iGame GTX 1080 Ti is sometime in April. That said, it seems very likely that the graphics card may only be released for the Chinese market.
(Source: VideoCardz)
