Huawei has just launched its new Huawei P10 series in Malaysia. These include the two devices launched at MWC 2017 – the P10 and P10 Plus – as well as the quietly announced Huawei P10 Lite.
Let’s start with the highest-end device in the series: the P10 Plus. For the Malaysian market, we’re getting the top-of-the-line 128GB variant with 6GB of RAM. The P10 Plus also features a 5.5-inch 1440p IPS display, the very capable Kirin 960 processor, a microSD card slot, as well as a 3,750mAh battery.
In the camera department, the P10 Plus has a a Leica-branded dual-camera system on the back, which is made up of a 20MP monochrome sensor and a 12MP RGB sensor. It also has an f/1.8 aperture and optical image stabilisation.
A tier down is the standard P10, and it’s packing a 5.1-inch 1080p IPS display, the same Kirin 960 processor, 4GB of RAM, 64GB of expandable storage, and a 3,200mAh battery. Although the P10 is equipped with a similar dual-camera system as the P10 Plus, it has a smaller f/2.2 aperture; it’s front camera, on the other hand, is the same Leica 8MP f/1.9 shooter found on the P10 Plus as well.
And then we have the most affordable device in the series, the P10 Lite. It packs a 5.2-inch 1080p display, a Kirin 655 processor paired with 4GB of RAM, 32GB of expandable storage, 12MP rear and 8MP front-facing cameras, as well as a 3,000mAh battery. It also has a glass back and a rear fingerprint sensor.
The Huawei P10 series will be available for pre-order in Malaysia on 23 March from Huawei Experience Stores, Lazada and Vmall. The P10 Plus retails at RM3,099, while the P10 and P10 Lite will go for RM2,499 and RM1,299 respectively. The P10 and P10 Lite will be available for purchase on 31 March, while the P10 Plus will go on sale on 15 April.
