Samsung opened this year on a positive note by announcing the 2017 version of its Galaxy A series in Malaysia recently. In China though, the company has decided to launch a different model called Galaxy C7 Pro.
Featuring a full metal body with a thickness of 7mm, the Galaxy C7 Pro is equipped with a 5.7-inch full HD (1920 x 1080) Super AMOLED display and is running on a 2.2GHz Qualcomm Snapdragon 625 processor. It also carries 4GB of RAM, and 64GB internal storage with support for up to 256GB microSD card.
In addition to that, the Galaxy C7 Pro also features the same 16-megapixels sensor and f/1.9 lens on both rear and front cameras although only the rear camera comes with a dual-tone LED flash. The phone also supports Samsung Pay and comes standard with a 3,300 mAh battery.
According to Samsung, there is also a liquid cooling system in the phone although this is not the same liquid cooling system that you have seen inside high performance PCs. Instead, it is actually a heat pipe-based system that that should be identical to the one (at least in concept) that Samsung has implemented on Galaxy S7 and S7 edge before.
Meanwhile, we don’t expect the Galaxy C7 Pro to be officially released into Malaysia though as the Galaxy C devices are traditionally available only in China, and Hong Kong. In case you still wondering, the phone will be made available for pre-order in China starting from today onwards.
(Source: Samsung China via GSMArena)
