Inno3D has announced what may just be the world’s first GTX 1060 graphics card with an AIO (all in one) liquid cooler. Prior to this, the only way for one to liquid-cool their GTX 1060 was to use to a custom waterblock. The graphics card in question is the iChill GTX 1060 Black and, aside from its built-in liquid cooler, also comes with beefy specs as well.
According to Inno3D, the iChill GTX 1060 Black comes with 6GB of VRAM along with 1,280 CUDA cores, 48 ROPs (render output units), 80 TMUs (texture mapping units), and a 192-bit GGDR5 memory bus. Interestingly, this graphics card is said to be equipped with the same custom PCB as its air-cooled sibling, the GTX 1060 iChill X3.
The crème de la crème of the Inno3D iChill GTX 1060 Black would, of course, be its AIO cooler. The liquid cooler used in this graphics card is the company’s Arctic Accelero Hybrid S AIO cooler, which features a ‘pump-block’ making that makes direct contact with the GPU itself. In addition, there is also a secondary-heatsink that comes with a 70mm fan which helps to cool the memory controllers and VRMs.
The iChill GTX 1060 Black is also fitted with a 120mm x 120mm radiator, which comes with a 120mm fan as well. When it comes to power consumption, the graphics card will be drawing power from a single 8-pin power connector. Connectivity options include one DVI, HDMI 2.0b ports each, along with three DisplayPort ports.
Unfortunately, it is unknown whether Inno3D plans to bring the iChill GTX 1060 Black to Malaysia. Furthermore, the company has not mentioned the graphics card’s pricing as well.
(Source: TechPowerUp)
