Colorful has announced its newest graphics card called the iGame GTX 1070 Snake X-Top. According to the Chinese company, its newest graphics card was designed for Snake eSports Clan, a League of Legends team. Unfortunately, there’s one problem: you probably won’t be able to buy it.
Specification-wise, the iGame GTX 1070 Snake X-Top features base and boost GPU clock speeds of 1667MHz and 1860MHz respectively. In addition, the graphics card is also equipped with a dual-BIOS features and a 10-phase VRM, which draws power via two 8-pin power connectors. The design of this graphics card is almost similar to other custom triple-fan GTX 1070s by Colorful, but is further endowed with a few ‘elements’ representing team Snake.
Sources mentioned that Colorful will only be producing about 200 iGame GTX 1070 Snake X-Top graphics cards. To add to the ‘limitedness’, it is said that this graphics card will only be made available for purchase in China; and a bulk of them is expected to be given away to the Snake team and its fans.
Colorful’s iGame GTX 1070 Snake X-Top will be priced at 3,999 Chinese Yuan (about RM2,560). Unfortunately, even if one were to be interested in a non-limited version of this graphics card (iGame GTX 1070 X-Top), it would be very difficult because Colorful graphics cards are rarely seen here in Malaysia.
(Source: VideoCardz)
