True to its previous announcement, ZOTAC’s new GeForce GTX 1050 Mini graphics card can now be obtained in Malaysia. In general, the new card is currently the most affordable Pascal-based graphics card by ZOTAC for the time being.
At a glance, ZOTAC GTX 1050 Mini comes with the same thermal solution that was used on the Mini variant of GTX 1050 Ti and GTX 1060 before. Specifically, the solution consisted of a sunflower-shaped aluminum heatsink that lies directly on the card’s GPU and cooled by a 90mm fan.
Equipped with 2GB of 128-bit GDDR5 VRAM that runs at 7 GHz, ZOTAC has also set the clock speed on GTX 1050 Mini identical to NVIDIA’s specifications with base clock of 1354 MHz and boost clock of 1455MHz. Just like the GTX 1050 Ti Mini, the card is powered solely through PCI Express port since it does not come with any power connector.
Available immediately in stores throughout the country, the new ZOTAC GTX 1050 Mini comes with a price tag of RM 579. Do note that each ZOTAC graphics card is covered with 5 years warranty.
(Image: MIT Technology, ZOTAC)
