NZXT has unleashed its latest limited edition PC case called the H440 Hyper Beast, which is based off of the standard H440’s chassis. According to the company, the PC case was made in collaboration with Brock Hofer, the genius behind the Hyper Beast skin found on Counter Strike: Global Offensive. Speaking of which, the graphics on this mid-tower case was, obviously, made to cater to CS:GO fans.
The main feature of the NZXT H440 Hyper Beast chassis, aside from the awe-inspiring design, is support for 240mm, 280mm, and 360mm liquid cooling radiators. In addition to that, the PC case is also equipped with four FNv2 cooling fans. Other specifications of the H440 Hyper Beast is similar to that of the standard H440 case.
Prior to this, NZXT’s immensely popular H440 PC case was also used to create the special edition ‘Designed by Razer’ H440 chassis as well. According to NZXT, it will only be manufacturing 1,337 (get it?) units of the H440 Hyper Beast PC case; each case also has a metal badge that displays a unique number.
The NZXT H440 Hyper Beast limited edition will be priced at US$200 (about RM840) and will be made available – in limited quantities – starting from late November. More information regarding NZXT’s CS:GO inspired PC case can be found here.
(Source: PCGamer, TechPowerUp)
