Another day, another iPhone 7 leak. The latest leak about the iPhone 7 we are seeing today is a video that seemingly confirms most of the rumours we’ve seen so far about such as the missing 3.5mm audio jack, larger camera, and more.
The video, posted on Weibo, shows a very similar design to what we saw just a couple of days ago. The video shows the back of an iPhone 7, clearly displaying the redesigned antenna lines that only goes across the top and bottom edge of the device. You can also see that the protruding camera is slightly larger than before, while the bottom of the phone now has two speaker grills, taking over what used to be the 3.5mm audio jack.
Sadly though, the larger iPhone 7 Plus is not shown in the video. The 5.5” iPhone 7 is said to come with a new dual-camera setup and yes, according to previous leaks, it too protrudes out of the device.
Also confirming that Apple will be removing the audio jack from the iPhone 7 is a set of images leaked about two days ago. The pictures show off the new Apple EarPod with Lightning connector. The Earpod looks identical to the existing earphones Apple is currently selling complete with inline buttons and mic however, instead of a 3.5mm connecter, there is now a reversible Lightning port.
Apple should be announcing the iPhone 7 in about September. We’ve seen plenty of rumours and leaks so far, along with photos. Let us know if you like what you’ve seen so far.
