Cooler Master has introduced the V650 and V750 power supply units to its V series PSUs. They feature an exclusive 3D circuit design, making them a compact ATX form factor power supply. Not only that, it also uses Cooler Master’s Silencio FP technology to provide quality airflow at low noise levels.
The V series power supplies feature a better overall build quality and has received the energy-saving 80PLUS Gold and Platinum ratings. The 3D circuit design rids the PSU of unnecessary cables by using full module boards. This gives the PSU a lower crosstalk and reduced signal noise. In turn, this ensures a better power output and improved heat dissipation.
On top of that, Cooler Master’s Silencio FP fans are also equipped in the V650 and V750. The blades are capable of generating 25% higher air pressure to reduce thermal de-rating on power components. Cooler Master also uses LLC and DC to DC topology to provide flat as well as constant output voltage which stabilises the voltage. Not only that, the power supplies’ cables are fully modular, featuring flat cables for easier management.
Cooler Master’s V650 and V750 targets both gamers and PC enthusiasts. They are now available for purchase in Malaysia, and will go for RM 549 and RM619 for the Cooler Master V650 and Cooler Master V750 respectively.
