Google will be unveiling two new Nexus devices in a couple of days’ time, but presentation slides of the Huawei-made Nexus 6P have already made it onto the Internet. The slides basically revealed all there is to know about Google’s latest Nexus, including a generous 3,450mAh battery and a premium construction.
According to the leaked slides, the Nexus 6P will be the first all-metal Nexus device. More likely than not, this would mean that LG’s Nexus 5X won’t have the same metal construction. Other than that, the Nexus 6P will indeed be powered by a Qualcomm Snapdragon 810 processor version 2.1, for better or worse.
Interestingly, the Nexus 6P will reportedly have a 5.7-inch 2560 x 1440 resolution AMOLED display, just like the current Nexus 6. The display will also be protected with the Gorilla Glass 4, which is said to be very difficult to shatter.
Rounding out the specifications of the Nexus 6P are 3GB of RAM, 12MP rear and 8MP front-facing shooters, USB Type-C, dual front-ported speakers, a fingerprint sensor, Android 6.0 Marshmallow out of the box, and three sizes of internal storage: 32GB, 64GB and 128GB. Seeing how the slides did not mention anything on expandable storage, a microSD card slot doesn’t seem to be present.
Google will be officially announcing the Nexus 6P and 5X on the 29th of September 2015. It will be the first time the company unveils two Nexus smartphones in the same year.
(Source: Imgur via Android Police)
