If you think that the Xpax Magic SIM is very attractive with free basic internet, freebies every time you reload, even more freebies when you subscribe to a high-speed internet plan, and the ability to carry forward unused internet, Xpax has just made things even better – low call rates. The telco recently revised its call rates to as low as 2.5sen/min.
Applicable immediately, Xpax’s call rates are now at 2.5sen/min (30sen/12mins block) for on-net calls, and 10sen/min (30sen/3mins block) for off-net calls. SMS rate remains the same at 12sen/SMS to all networks. Previously, Xpax charged a fixed rate of 12sen/min for calls to all-networks.
The new rates are as follows:
What makes Magic SIM stand out compared to the rest of the prepaid telcos out there is it comes with freebies each time you reload your number. The telco will give free high speed internet, as well as free calls and SMS every time you perform a reload from RM5 and above. That’s not all, the telco will give away even more free high speed internet, and calls & SMS each time you purchase an internet pass from them. If you can’t finish using up your free data, you can even carry forward unused internet (T&C applies).
Check out Xpax now for more information. The telco is also giving away free Xpax Magic SIM prepaid packs, so if you wish to enjoy the freebies and such, check out our previous post for more information.
