Bought an iPhone 6 Plus between September 2014 and January 2015, and have a faulty camera that always seems to take blurry pictures? Apple recently launched an iSight Camera Replacement program that will replace the camera in your affected device for free.
Check if you are eligible for the replacement program over at Apple’s website. The company says that a small percentage of iPhone 6 Plus were affected by the faulty camera, causing photos to look blurry. The affected units fall into a limited serial number range. If eligible, Apple will replace your device’s iSight camera for you for free.
Apple will first examine you device to confirm that it is eligible for this program and is in working order. Do make sure you back up your data to iTunes or iCloud before sending it in for a camera replacement.
Do note that Apple may restrict or limit repair to the original country of purchase. If there are any physical damages that impairs the camera replacement, you will need to fix it prior to service. Once claimed, it does not extend the standard warranty coverage of the iPhone 6 Plus. This program covers affected iPhone 6 Plus iSight cameras for 3 years after the first retail sale of the unit.
Visit Apple’s website for more information and to check if your device is eligible.
