Home Mobile Phones iPhone
Rumour: Next iPhone to be Faster, Have Better Battery Life, New NFC Chip and More
by Huei Song
July 7, 2015
iPhone 6s Metal Body
It’s been almost 10 months since Apple unveiled the iPhone 6 and iPhone 6 Plus. This means that the next generation iPhone, presumably the iPhone 6s, is around the corner, and here are some of the latest rumours that we’ve seen so far.
First up, as its name suggest, the iPhone 6s will feature minimal changes on the outside. According to several leaked images claiming to be the shell of an iPhone 6s, and sources of 9to5Mac, the upcoming device should almost be identical and any difference in thickness or width on the iPhone 6 would be too minimal to notice. The source also noted that this is only applicable to the iPhone 6s and doesn’t rule out changes to the larger iPhone 6s Plus.
iPhone 6s Rear Camera without Dual Camera Setup
Despite Apple’s recent patent application to hide the antenna line on the back with an “anodized metal appearance”, the pictures are still showing the same old plastic antenna lines. Other things to note from the pictures include the same camera setup, and same connectors, speakers and microphones.
The real changes takes places on the inside of the iPhone 6s frame. The mounting points have been changed for new logic board and components. According to several leaked photos of the logic board of an iPhone 6s, the device will have an updated NFC chip, fewer chips on board, and a new flash memory that will start from 16GB.
iPhone 6 vs iphone 6s Logic Board
Finally, another major changes to the innards of the iPhone 6s would be its redesigned wireless system that features a new Qualcomm-made LTE chip. The device will use a Qualcomm MDM9635M chip (also known as “9X35), which has a significant performance over the 9X25 chips found in the iPhone 6 and iPhone 6 Plus. The new modem is capable of delivering up to twice the theoretical LTE download speeds – potentially up to 300Mbps.
iPhone 6s New LTE with Double the Speeds
Are you looking forward to the next generation iPhones? Check out the source links below for more information and more pictures.
(Source: 9to5Mac 1, 2, 3)
Filed Under iphone 6s cameraiphone 6s leaksiphone 6s plusiphone 6s plus rumouriphone 6s rumouriphone 6s rumoursiphone 6s specsRumour
Updated 2:05 pm, Tue, 7 July 15
http://lowy.at/lZekC
SendShareShareShare1Tweet1
    Transportation
    Cyber Security
    5G Infrastructure
    iPhones May Finally Support 5G Standalone And 5G Advanced In Malaysia Via Upcoming Update
