Huawei did not just launch the P8 and P8 Lite in Malaysia today. Announced alongside them are three new Android devices: the MediaPad T1 7.0 tablet, and the Y3 and Y5 smartphones, which are priced from as low as RM249.
The most affordable of the bunch is the Huawei Y3, which retails at RM249. In terms of specification, it has a 4-inch 800 x 480 resolution display, a Spreadtrum 7731 1.3GHz quad-core processor paired with 512MB of RAM, 4GB of internal storage which can be expanded with a microSD card up to 32GB, and a 1,730mAh battery. In the camera department, there’s a 5MP rear camera and a 2MP front-facing shooter.
The Huawei Y5, on the other hand, retails at RM339. It’s powered by the same processor as the Y3, and it also has a bigger 4.5-inch 960 x 540 resolution display, 1GB of RAM with 8GB of internal storage (also expandable with a microSD card), and 8MP rear and 2MP front cameras. Other than that, both the Huawei Y5 and Y3 are running on Emotion UI 3.0 Lite based on Android 4.4 KitKat, feature 3G connectivity, and dual-SIM support.
Last but not least is the Huawei MediaPad T1 7.0, which retails at RM649. This tablet has a 7-inch 1024 x 960 IPS display, a Spreadtrum SC7731G 1.2GHz quad-core processor paired with 1GB of RAM, 8GB of internal storage, a microSD card slot that supports cards up to 32GB, a 4,100mAh battery, and Emotion UI 3.0 based on Android 4.4 KitKat out of the box. It also has a 2MP rear and 2MP front cameras.
To recap, the Huawei Y3, Y5 and MediaPad T1 7.0 retail at RM249, RM339 and RM649 respecitvely. These devices are now available at all Huawei authorised stores in Malaysia.
