Now that you have a USB-powered LED light, what about a USB-powered fan? It looks like Xiaomi may just bring its neat little gadget to Malaysia.
According to our friend in Xiaomi, Joshua Ong, Social Media Marketing Manager, the company is considering on bringing in the Mi-branded USB-powered fan. The fan is currently being sold in China for about 20 Chinese Yuan (about RM12). It is a small little gadget measuring at only 145.5 x 15 x 89.3mm, and for easy storage, the top of the fan is removable too.
Sadly though, while the USB fan looks like a “Take-copter” gadget in popular Japanese animation, Doreamon, it is noted that even if you have a USB port on the top of your head, it will not make you fly. Similarly, it will not make your gadgets fly either.
I think the fan goes perfectly with the USB LED light from Xiaomi, as well 16,000mAh Mi powerbank with two USB ports. The next time there’s a power cut, just plug the two gadgets into the power bank and you’re good to go for the next couple of hours and even the next few days.
Check out Xiaomi for more information about its USB-powered fan.
(Source: Joshua Ong)
