On showcase alongside the Asus Zenfone 2 in Jakarta are a slew of accessories for it. These include two flash accessories, two earphones, and as many as five different power banks.
The two flash accessories on showcase today are the Zenflash and Lolliflash. The Zenflash is the more powerful of the two and is attached to the back of the Zenfone 2 with suction cups. In order to use it, users will have to connect it to the smartphone via USB and use an app to presumably control it.
The Lolliflash, on the other hand, will work with any smartphone as it is basically a flash device that connects to an audio jack. Unlike the Zenflash, it can be used without being connected to the phone as it has its own battery. It also has three different colour filters that act as protective covers.
Next, we have two different earphones from Asus. Unfortunately, not much has been made known about these two earphones yet. All that we were told is the fact that the ZenEar S is the more premium product, while the regular ZenEar is the cheaper one. The ZenEar S does feature a metal construction and a braided cable, which gives it a rather premium vibe.
Last, but definitely not least, are five different Asus power banks. Unfortunately, only one of the five is an actual product, which is dubbed the ZenPower. The other four products are merely mock-ups at this point in time. In any case, the ZenPower is a 10,050mAh power bank in a rather compact enclosure that can be protected with a rubber case. With an output of 2.4A, it also supports quick charge on devices that have the feature.
Yes, we are also wondering why these are labeled as 10,000mAh power banks instead of 10,050mAh.
The mock-ups
In Indonesia, the Zenflash and Lolliflash will go for 239,000 rupiah (about RM65) and 119,000 rupiah (approximately RM33) respectively. The ZenEarS and ZenEar, on the other hand, retails at 699,000 rupiah (around RM195) and 79,000 rupiah (approximatley RM22) respectively. Lastly, the ZenPower is set at 269,000 rupiah (about RM75). While the Malaysian availability of these accessories has not been announced yet, we imagine it would launch sometime after the Asus Zenfone 2 is made available in Malaysia on the 9th of May.
