The BenQ B502 is now available for pre-order in Malaysia for RM499. This particular mid-range smartphone may look like any other device in the market, but it boasts several standout features such as a 6.99mm thin body and a 13MP rear camera.
Specification wise, the B502 has what you’d expect out of any mid-range Android smartphone. It has a 5-inch 720p IPS display and is powered by a Mediatek MT6582 quad-core processor clocked at 1.3GHz with 2GB of RAM. It also has 16GB of internal storage which can be further expanded with a microSD card up to 32GB.
Other specifications include a 13MP rear camera, a 5MP front-facing shooter, BenQ’s own Q Home UI which is based on Android 4.4.2 KitKat, and a rather small 1,800mAh non-removable battery, which is a little disappointing. The B502 is also rather light at only 125 grams.
The BenQ B502 is now available for pre-order at SuperBuy. If you purchase the B502 at SuperBuy from today onwards until the 22nd of March 2015, you can get it for RM499 instead of it’s retail price of RM599. On top of that, you will also get a free Smart Casing, screen protector and earphones that are worth RM128.
Is this smartphone for you? Find out in our upcoming lightning review of this affordable smartphone from BenQ!
