If you’re itching to get your hands on the new ZOTAC GeForce GTX 960 graphics card, then Storekini has you covered. Retailing at RM849, Storekini is giving RM100 off the standard edition of the ZOTAC GTX 960, and as much as RM150 for the AMP! Edition that retails at RM949.
As we have previously written, the ZOTAC GTX 960 is bundled with a copy of Metal Gear Solid V: Ground Zeroes, which complements the graphics card well considering how demanding the game is in terms of graphics. Even if you’re not a fan of the game, a free game is always nice.
The ZOTAC GTX 960 standard and AMP! Edition have certain differences, such as a base clock speed of 1177 MHz (up to 1240 MHz) and 1266 MHz (up to 1329 MHz) respectively. The AMP! Edition also features dual 90mm fans and a set of metal back plate and front frame that ZOTAC dubs ExoArmor. Other than these differences, both graphics card are identical, with 2GB of GDDR5 memory running at 7010 MHz, one DisplayPort, one HDMI 2.0, and two dual-link DVI ports.
If you need a more powerful graphics card, Storekini also has the Leadtek GeForce GTX 970 HURRICANE and Plextor M6S 128GB SSD bundle in store. Specification wise, the Leadtek GTX 970 has a base clock speed of 1079 MHz that goes up to 1216 MHz. In terms of connectivity, it has DisplayPort, HDMI and dual-link DVI ports.
The ZOTAC GTX 960 promotion will go on while stocks last. The Leadtek GTX 970 and Plextor M6S 128GB SSD bundle, on the other hand, will end on 28th February. You can make your order over at Storekini’s website for the ZOTAC GTX 960 standard edition, AMP! Edition, and the Leadtek GTX 970 and Plextor SSD bundle by clicking on each respective product link.
