Microsoft has expanded the list for the Windows 10 Technical Preview for phones to cover even more Lumia devices. There are still some glaring holes in the list, like the Lumia 930; although it is nice to see the Technical Preview arriving on the Lumia 1020 and 1520.
The limited number of initial phones was due to the fact that some devices simply did not have enough of a partition size for the operating system to be installed and then still have enough room for future updates. However, it looks like Microsoft has solved the problem with something called “partition stitching”, that allows the the system partition to be dynamically resized.
Microsoft has provided a caveat for the list of Lumia devices that support the Windows 10 Technical Preview. It says that if it discovers a device specific bug, it may pull that device from the list. However, the company says that any Lumia phone not on the list may also appear if they manage to fix the device specific bugs before the next release.
The new list of supported phones is:
- Lumia 1020
- Lumia 1320
- Lumia 1520
- Lumia 520
- Lumia 525
- Lumia 526
- Lumia 530
- Lumia 530 Dual Sim
- Lumia 535
- Lumia 620
- Lumia 625
- Lumia 630
- Lumia 630 Dual Sim
- Lumia 635
- Lumia 636
- Lumia 638
- Lumia 720
- Lumia 730
- Lumia 730 Dual SIM
- Lumia 735
- Lumia 810
- Lumia 820
- Lumia 822
- Lumia 830
- Lumia 920
- Lumia 925
- Lumia 928
- Lumia ICON
- Microsoft Lumia 430
- Microsoft Lumia 435
- Microsoft Lumia 435 Dual SIM
- Microsoft Lumia 435 Dual SIM DTV
- Microsoft Lumia 532
- Microsoft Lumia 532 Dual SIM
- Microsoft Lumia 640 Dual SIM
- Microsoft Lumia 535 Dual SIM
[Source: Microsoft via Engadget]
