Home News
Brick Dropped on Moto 360 for Durability Test, Shatters Display
by Andrew Cheng
December 17, 2014
moto-360-durability-test-3
Durability tests for gadgets are not new; many people use the results as a gauge of how long a device will last. This particular test on the Motorola Moto 360, however, is a durability test of the more extreme kind. While the water and scratch resistance test were pretty sound, the impact resistance test involved dropping a huge brick.
In Android Authority’s “durability” test of the Moto 360, the smartwatch was submerged in a bowl of water for 40 minutes. The 360 was checked periodically in 10 minutes intervals to make sure that it was still functioning. As expected, it managed to pass this test rather easily. The IP67 certification sure isn’t just for show.
moto-360-durability-test-2
moto-360-durability-test-1
As for the scratch resistance test, the smartwatch was rubbed on two kinds of surfaces: a metal railing, and a concrete floor. Surprisingly, the Moto 360 came out almost unscathed after being rubbed pretty aggressively on the metal railing. On concrete floor, however, it didn’t fare that well.
Finally, there’s the impact resistance test. There’s a lot of other more realistic ways to perform this test, such as banging it against a table or a wall. Instead, Android Authority decided that dropping a brick on the Moto 360 would be a better idea. Unsurprisingly, the brick shattered the glass display. It is doubtful that any device with a glass display would be able to survive this impact resistance “test.”
moto-360-durability-test-4
For those of you who would like to see these tests in action. here are the minute markers for the water, scratch, and impact resistance tests, respectively: 1:45, 6:27, and 9:33.
Youtube video
(Source: Android Authority)
Filed Under motomoto 360Motorola
Updated 4:02 pm, Wed, 17 December 14
http://lowy.at/kk0Zp
SendShareShareShare1Tweet1
    OS
    Samsung Begins One UI 8.5 Rollout For Older Devices
    EPF Introduces i-Legasi, i-Emas, And Retirement Goal Calculator
    Rumours & Leaks
    Valve Reportedly Preparing Four Steam Machine Packages
    Transportation
    Tony Fernandes Plans To Launch New Airline
    Next-Gen MyKad To Feature 53 Security Elements But No Touch ‘n Go
