Christmas is around the corner and if you’re looking for a tech gift, then look no further. Storekini is currently holding a preorder for the Cooler Master Ergostand III, an ergonomic cooling pad for your laptop, for RM149. The first 10 customers will even walk away with a free Power Fort 6600mAh powerbank worth RM89.
The Cooler Master Ergostand III isn’t just a regular laptop cooling stand, it also acts as a USB hub with 4 built-in USB ports for expanded device connectivity. It has 6 adjustable height settings for optimal viewing or typing angle, and a large 230mm silent fan with exclusive fan blade design for better air dissipation, and has a removable diamond mesh fan cover for easy cleaning.
Compatible even with tablets and other mobile devices thanks to its anti-slip holder, the Cooler Master Ergostand III is available for preorder at Storekini for RM149 from 3 – 17 December 2014. On top of that, if you’re the first 10 customers to purchase it during the preorder period, you will also get a 6600mAh Power Fort powerbank worth RM89 for free. The Ergostand III will be sent out at the end of the preorder period, just in time for Christmas.
Visit Storekini.com now to find out more about the preorder.
