If you’re looking for a new wireless speaker, then look no further because our colleagues at Storekini is now offering the Logitech x300 Mobile Wireless Speaker and as always, the store will also throw in freebies for every purchase.
Starting today to 14 November 2014, Storekini is offering the Logitech x300 Mobile Wireless Speaker for RM259 and on top of the speaker, in conjunction with Logitech’s 33rd birthday celebration, the first 33 customers will receive a RM33 Storekini voucher. Each purchase of the x300 Mobile Wireless Speaker also entitles you to a purchase-with-purchase deal – just add on RM50 to get a Logitech Noise Isolating Headphones (RRP RM99).
The Logitech x300 is a wireless speaker that is “designed for performance”. Do not judge it by its small and portable size because it packs a punch on the inside, delivering deep, precise bass response, and detailed mid and high-range sound. Compatible with most mobile devices (Windows Phone 8, OS X, iOS and Android), the x300 can easily be connected either via Bluetooth-wireless audio profile or via the 3.5mm audio output; it also supports phone calls using Bluetooth-Hands-Free Profile (HFP1.6). Other specs include 30feet wireless range, 5 hours battery life, and measures at 69 x 152 x 71mm.
Visit Storekini now to purchase the X300 Mobile Wireless Speaker from them, you better be quick because the free RM33 Storekini voucher is limited to the first 33 customers only. There are 3 colours for you to pick from – black, blue and red.
