First announced to the world at the end of 2013, the Cooler Master HAF Stacker PC casings are known for their modular capability that is made possible through the rail system that is present on each of them. As this system allows users to stack casings from HAF Stacker series on each other, it provides plenty of expansion room to suit users’ needs.
Two models from the series (HAF Stacker 935 and HAF Stacker 915R) have recently arrived on our Storekini online shop and in conjunction with their arrival, each purchase of these casings will be accompanied by the Stacker Transformer Packs. This offer doesn’t last long though…
But first: what is the Stacker Transformer Pack? Well, that depends on which model you mean.
If you didn’t realized it, the HAF Stacker 935 is actually a combination of a HAF Stacker 935 unit and HAF Stacker 915 on its top area. So, the Transformer Pack for HAF Stacker 935 provides couple of components for the HAF Stacker 915 section to users to utilize it as a standalone unit such as a top panel, windowed side panel, case stand, and I/O front panel.
As for the HAF Stacker 915R, its Transformer Pack includes a cage for users to mount more hard drive within the case as well as windowed side panel.
Available for RM 559 and RM 239 respectively, this particular promo will last until 13 May. To know more, check out the listing for Cooler Master HAF Stacker 935 and HAF Stacker 915 at Storekini but of course, if you have further questions to ask, you can get in contact directly with our Storekini colleagues over at fb.com/Storekini.
