Over the past week or so, most of the iPhone 6 leaks have been pretty consistent, showing off a rounded edge and a much thinner design compared to current generation iPhone. Today’s leak, shared by none other than Nowhereelse.fr, is a set of pictures that shows off something very similar too.
As you can see in the images above, the pictures appears to be some sort of physical mockup of the iPhone 6 design we’ve been seeing so far. Nowhereelse said that the pictures have been published by a member of a well-known Chinese forum. The purpose of the mold isn’t clear, but could be something case manufacturers use to validate and refine case designs.
As usual, take the leaks with a pinch of salt, this could very well be a mold made based on the other leaks we’ve been hearing so far.
Meanwhile, check out some iPhone 6 leak and concepts that have been published over the past couple of days.
If this is indeed the final design of the alleged 4.7” (and maybe 5.5” as well) iPhone 6, will you consider getting an iPhone?
(Source: 9to5Mac 1, 2, 3, Nowhereelse.fr)
