XFX might has made its mark in the market through the company’s high-end graphics cards but alongside those feisty GPUs, XFX has also manufactured other types of product such as power supplies, accessories for multi-GPU setup, and mouse pad. This year, the company has also decided to jump into PC chassis business by releasing the new XFX Type 1 Bravo mid-tower case.
Made for standard ATX motherboards, the XFX Type 1 Bravo’s base is slightly raised from the ground in order to create space for cool air which then can be pull into the case – the company refers to this as the “floating design”. Comes standard with a 140mm LED rear fan, XFX Type 1 Bravo is able to support up to 8 fans throughout various of the case.
Apart from having a bottom mount power supply area and enough room for eight PCI-Express cards, the XFX Type 1 Bravo case also features tool-less drive slots that are able to fit three 3.5-inch drives and five 2.5-inch drives. The case I/O ports are located on the top of the case which include four USB 3.0 ports, one microphone input and one audio output.
The local availability of the XFX Type 1 Bravo case is not yet known at the time being but if you need an indication of its price, the case is listed at USD 129 (RM 432) in United States. To see more, check it out at xfxforce.com.
