Have too many devices but not enough SIM cards to keep them connected while you’re on the go? No problem because DiGi has a device for such situations. The telco has just introduced a new Wi-Fi hotspot device called MobiFi that allows you to share your internet with up to 10 different Wi-Fi enabled devices. MobiFi is available at selected DiGi Stores from as low as RM7/month, and can be used together with any one of the telco’s three mobile broadband plans starting from RM25/month.
DiGi is offering two new models of MobiFi devices – 3G MobiFi from as low as RM7/month, and a 4G LTE MobiFi at RM18/month. Both models comes with a built-in battery, and both a wall socket charger and an in-car charger for true mobility.
The broadband plans offered for MobiFi includes:
- Broadband 25 – 1GB of data at RM25/month
- Broadband 45 – 2GB of data at RM45/month
- Broadband 65 – 8GB of data at RM65/month (4GB (for whole day usage) + 4GB (for usage between 2am to 8am)
If you are an existing DG Postpaid subscriber, you will get a RM5 discount if you sign up for any of the broadband plans. For those of you who do not require an additional device, you can also opt to sign up for a SIM-only subscription.
Visit DiGi to find out more about their new MobiFi device as well as the broadband plans offered with the router.
