You know how troublesome it is whenever you wish to transfer data from your Android device to your computer – you’ll need to hook it up to your PC using a cable, pull out the memory card or rely on Bluetooth just to get a simple task done? Well, say goodbye to all those because SanDisk recently announced the SanDisk Ultra Dual USB drive that comes with two USB ports – a full sized one for your computer and a microUSB port that connects to most Android devices, allowing you to quickly and easily transfer files between different devices.
Measuring at a tiny 3.5cm long by 2cm wide, the SanDisk Ultra Dual USB Drive comes with a microUSB port on one end and a USB 2.0 on the other. Available in 16GB, 32GB and 64GB, it should work with almost all Android smartphone and tablets, allowing users to not only easily transfer files around, but also provide extra storage space – especially useful for those with non-expandable storage. It’s a plug-and-play device that is automatically detected when connected to a compatible Android smartphone, tablet or computer. The USB drive also works with the company’s own SanDisk Memory Zone App that provides an easy way to manage, organize and back up files stored in the internal and external memory of your Android device. Check out the video below to find out more.
https://www.youtube.com/watch?v=pNk-feu0CvQ
(Source: Android Police, SanDisk)
