You wouldn’t think that Lenovo, the company that has already introduces a whole load of devices for the year, to move on without adding more ThinkPad to its range of devices would you? Introduced at CES are the ThinkPad T430u, ThinkPad Edge S430 and 11, 13, 14 and 15 ThinkPad Edge laptops.
Who says ultrabooks are only aimed at normal consumers for typical day-to-day usage? The ThinkPad T430 is the first business ultrabook from Lenovo that is equipped with the same thin and light designs found in consumer ultrabooks except that it comes with business-class performance. It comes with a matte finish with an aluminium top cover that surrounds its less than 2cm thin design.
As for the specifications, it will be packed with Intel’s Core Processors and Intel integrated or NVIDIA graphics, and you can choose between SSD storage or up to 1TB of HDD capacity. As for the battery life, it can churn out up to 6 hours of usage. Further setting this ultrabook apart from the consumer range is the company’s Solution Center powered by Intel Small Business Advantage, a set of productivity and seciruty tools helping to enable overnight energy savings and automatic patch updates.
Hit the break to check out the ThinkPad Edge 430 and ThinkPad Edge 11, 13, 14 and 15 laptops.
ThinkPad Edge S430 – Style & Substance to Succeed
Business laptops do not always need to be boring and ugly looking. The ThinkPad Edbe S430 is targeted at image conscious professional. Available in Mocha Black, this laptop measures at less than 2.5cm thin and comes with metal accents, a soft-touch finish encased in an elegant thin and light design. The 14” laptop also comes packed with the features SMBs need to succeed with choices of the latest Intel Core processors, a DVD burner or a second hard drive for up to 1 TB of storage, choices of Intel integrated or NVIDIA Optimus graphics, Dolby Home Theatre v4, USB 3.0 ports and Intel Thunderbolt™ Technology. With Thunderbolt™, users can transfer a full-length HD movie in less than 30 seconds and backup a year of continuous MP3 playback in just over 10 minutes.3 The laptop also comes with Lenovo Solution Center powered by Intel Small Business Advantage, a set of productivity and security tools helping to enable overnight energy savings and automatic patch updates.
ThinkPad Edge 11, 13, 14 and 15 Laptops – Designed to Perform
Whatever size it is you want, you can be sure that Lenovo has them. Introduced at CES are the new ThinkPad Edge E135, E335, E430 and E530 laptops coming in the size of 11”, 13”, 14” and 15” respectively.
The higher range are the ThinkPad Edge E430 and E530 that give SMBs the freedom to choose their level of performance with options of the latest Intel Core processors or AMD Fusion APUs (on the E435 and E535 laptops) with choices of integrated or discrete graphics. The laptops also feature fast boot up, up to 1 TB of storage that can be combined with solid state drive storage, USB 3.0 ports and a high resolution web camera. The laptop models with the latest Intel Core processors also include Lenovo Solution Center powered by Intel Small Business Advantage.
The smaller 11.6” ThinkPad Edge and 13.3” laptops give SMBs the ability to optimise their performance and mobility with the latest Intel Core processors on the E130 and E330 or AMD Vision Accelerated processors on the E135 and E335 laptops.
The mainstream ThinkPad Edge laptops also feature an attractive graphite grey interior with choices of Midnight Black, Heatwave Red or Cobalt Blue covers, featuring the same progressive design of the ThinkPad Edge S430 laptops.
